HID wiring
Old Jan 6, 2016 | 01:04 AM
stupots's Avatar
Default HID wiring
hi
I am fitting a hid kid this week on my 2010 2.2 x type diesel estate. It seems according to the handbook if you have hid you have a 10 amp fuses or ordinary bulbs a 7amp fuse.
question as all x types have the projector type dip headlights lens, is the wiring harness the same regardless what bulb you have just the fuse is rated different?
thanks
Old Jan 6, 2016 | 02:24 AM
JagV8's Avatar
You know they're illegal?
(Unless you fit full OE and headlamp washers, etc.)
Old Jan 6, 2016 | 03:07 AM
stupots's Avatar
hi my x type is a 2010 2.2 diesel estate with head light washers
Old Jan 6, 2016 | 08:12 AM
I've moved your question from General Tech Help to X-Type forum. This is the place to post technical questions about your model.
Old Jan 6, 2016 | 01:04 PM
joesoap's Avatar
I would be surprised if harness is the same, Halogen bulbs usually have a connector which fits on the bulb end like 3 spade connectors in 1 with 1 at 12 oclock the other 2 at 9 and 3 oclock.
HID bulbs like D2S have an entirely different base, unless they are aftermarket which can be bought to match the original halogen bulb type.
As for the fuse it probably has 10 amp for HID because of start up current surge although they are rated 35w as opposed to 55w for halogens.
Old Jan 7, 2016 | 02:07 PM
Thermo's Avatar
Veteran: Navy
stupots, the factory HID headlight housings have dual ground wires (pins 9 and 10 as I recall) where the halogen headlight housings have a single ground wire (pin 9). Keep in mind that when an HID bulb starts, each bulb pulls about 20 amps (40 amps total). This is why the HID headlight housings have dual ground wires.
As for mounting an aftermarket HID system into your car, the factory wiring between the battery and the headlight housing is ok, but you should ground the HID ballast to the frame of the car to prevent any issues with the headlight ground wire.
If there are more questions about HIDs, let me know. Wiring is what I do for a living and I can help you get a bulletproof system.
Old Jan 10, 2016 | 12:19 PM
JagV8's Avatar
UK also requires self-levelling.
Must inform insurer of the mod.
HID need different headlamps (housings etc), too.
18686medic
Jul 4, 2025 10:12 PM
al_roethlisberger
Jun 27, 2023 12:17 PM
Mickeyluv
Mar 29, 2016 07:23 PM
NTL1991
XJ40 ( XJ81 )
Jan 10, 2016 03:30 PM
ynotfl62
Jan 1, 2016 12:46 AM
