Hight low Throttle
Old May 15, 2016 | 12:51 AM
curtizb's Avatar
Default Hight low Throttle
I have the 2002 X type 5 Speed
I have an issue were the throttle is going high and low. I start the car and it goes up to three right off the bat but it's going back and forth on the idle. I notice it most while going up hill where is almost stalls. New fuel Pump and other things cant figure it out.. Seems to be like a compression issue?
Any help? Thnkas
Old May 26, 2016 | 05:36 PM
Rchiv's Avatar
Hi, Have you had the codes read. Sounds like there is confusion between the throttle position and the ECM. Have you tried a hard reset. Disconnect the battery and join the leads together for a few minutes then reconnect the battery. The car will reset all modules etc.
Roger
Old May 27, 2016 | 02:12 AM
JagV8's Avatar
If it's a petrol then look at fuel trims as could be an air leak.
