Horn Failure, any suggestions ?
Old Mar 24, 2011 | 05:00 PM
Thermo's Avatar
Veteran: Navy
Brian, first off, welcome to the forums. You will find lots of useful information here. So, sit back, grab a cup of joe and learn a few things about your car.
Secondly, we ask that you introduce yourself in the new member section. Helps others get a feeling for who you are and what brings you here. So, if you would please, stop by and tell us a little bit about yourself.
As for your problem. What I would tell you to do is to first prove the horns work themselves. If you look on the horns, you will see a single wire coming off of them. Disconnect this wire and then install a jumper wire between the positive of the battery and the connector on the horn. Did the horn sound? If no, then you have a bad horn. Buy a new horn. If the horn does sound, then let me know and I will give you a few more checks to make. Most of the time it is simply the horn giving up the ghost from being exposed to the elements over the years.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
kurtomatic
Sep 26, 2015 10:31 PM
Tim Goz
Sep 17, 2015 09:11 AM
colinc1444
Sep 14, 2015 07:54 PM
