hose assembly, upper radiator...
Old Aug 12, 2012 | 09:40 PM
afonda's Avatar
Default hose assembly, upper radiator...
Hi guys... Any idea where to buy this part? Is it dealer only?
I have a leak in the hose that comes off the drivers side top of the radiator.
Looks like only part of this upper radiator hose assembly.
afonda
Old Aug 13, 2012 | 02:58 AM
disguay's Avatar
a picture of what you are talking about would probably get you a little bit more accurate response.
Old Aug 13, 2012 | 07:18 AM
Can you identify the part more precisely with reference to this Parts Manual diagram?
Jaguar X Type - Radiator Hoses.pdf
Old Aug 13, 2012 | 09:03 AM
afonda's Avatar
apparently it is called the upper hose assembly. Jag Part# C2S43430
in your diagram it is #7. to be more exact, in this diagram, #15 points to a hose clamp... The hose that clamp goes on is the one i have a leak in.
Seems stupid that I have to purchase the entire upper assembly in order to replace one silly 12 inch radiator hose.
Thank you Jaguar!!!
Old Aug 13, 2012 | 09:29 AM
With the right angle hose you need not showing as available separately, there seems no sense in listing Hose Clamp #13!
This any use to you as an alternative to the dealer:
JAGUAR UPPER RADIATOR HOSE ASSEMBLY X TYPE C2S43430 | eBay
Old Aug 13, 2012 | 08:46 PM
afonda's Avatar
Default specs???
any way to get the specs on this right angle hose that I need?
I just need to know the Inside Diameter on each end of the hose.
Old Aug 15, 2012 | 09:13 PM
afonda's Avatar
Default bump
anyone know the Inside Diameter of this radiator hose?
Pristine97XK8Convertible
Mar 5, 2025 10:32 AM
GGabriel
Nov 22, 2018 03:53 AM
thedugger1
Sep 26, 2015 10:27 PM
Jaguar Forums Editor
Jaguar Press release
Sep 25, 2015 11:58 AM
