housing within the thermostat housing
Old Sep 18, 2013 | 12:20 PM
akubeta's Avatar
Default housing within the thermostat housing
I got a seized/broken bolt in the thermostat housing, is there a way to remove the housing of the thermostat housing? is it easy to remove or will I have to remove the water pump to get to it? I want to take it out and get a bolt removal specialist to take the broken bolt out, rather than risk drilling it out at a crazy angle, no space. (x-type 2002)
Old Sep 20, 2013 | 07:06 PM
Jeeves12's Avatar
akubeta,
Are you talking about the bolt that hold the thermostat housing together or the bolt that holds the thermostat housing to the engine block?
If it's the bolt holding the thermostat housing together, try a pair of channel locks or vise grips and squeeze on the housing half opposite of the bolt head. There is a nut that is nilled (not sure of the proper term) that is set into the plastic housing. So by squeezing the plastic housing it should stop the inset nut from spinning. Drill out the nut part and then buy a longer bolt and anf nut to reassemble.
It it's the bolt into the engine block. Try a center punch and hammer to spin the broken bolt. Hopefully, there is an easier way and someone will help out.
Old Sep 25, 2013 | 10:35 AM
akubeta's Avatar
Originally Posted by Jeeves12
akubeta,
Jeeves12:
Would you know how I get the thermostat housing out of the engine block?
Old Sep 26, 2013 | 06:38 PM
Jeeves12's Avatar
Can you take a picture of the part in question? I would soak the bolts with JB Blaster and then try to take the bolts out. I'm not sure, if we are talking about the same part.
mikiep
Dec 20, 2019 07:37 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
Lubrication
Oct 1, 2015 03:56 AM
zoozth
Sep 29, 2015 07:28 AM
hoodun
Sep 28, 2015 08:32 PM
