How much anti-freeze needed?
Old May 24, 2016 | 05:27 AM
xtype62's Avatar
Default How much anti-freeze needed?
Hi! How much anti-freeze should I top-up with(most of it drained off)in my X Type 2.1 V6? Thanks
Old May 24, 2016 | 06:26 AM
DPK's Avatar
DPK
Just going by my X...I filled it according to the dealer, to the bottom of the black top. Basically fill until it goes above the translucent plastic section....If yours is like that, otherwise fill to the max line if there is such a thing on yours...Be sure to use distilled water if you are doing the mix yourself.
Old May 24, 2016 | 10:27 AM
Thermo's Avatar
Veteran: Navy
xtype62, plan on using about 8 liters of coolant that is 50/50 mix. If you buy the concentrate, then you will get 4 liters of the concentrate and then 4 liters of distilled water (not purified, not tap water). This capacity is coming from the owners handbook. The 2.1L motor may take slightly less, but it is better to have a bit too much than not enough.
Old May 24, 2016 | 11:39 AM
Lemons Racer's Avatar
Remember to check it again after you get to running temperature then let it cool. DO NOT open while hot. After the thermostat opens the coolant will circulate around the system and fill in any pockets, so if it wasn't filled to Thermo's specs you may need to add more.
cbroth1
Dec 23, 2021 08:11 AM
rmiklosh
Jun 9, 2016 12:38 AM
chtp66
May 24, 2016 02:56 PM
MI-FType
May 10, 2016 08:26 PM
Jacsun
May 8, 2016 07:26 AM
