How to remove the center caps on rims
Old Jul 3, 2016 | 11:01 AM
harryc's Avatar
Default How to remove the center caps on rims
The center caps in my rims are all worn and need replacing. I have the 6 spoke 17 inch rims. How do they come out? Are they simply pressed in? Do you have to remove the wheel?
Old Jul 3, 2016 | 11:51 AM
RobinGa's Avatar
I suggest removing the wheel then simply press out from the inside. Plenty of pictures of them available to see online if you search to see the design of how they are made. You would probably damage them or clear coat on the wheels by prying them out with wheel still on the car.
Old Jul 3, 2016 | 02:59 PM
hlgeorge's Avatar
If you are going to replace them and toss the old ones, just drill a hole in the center of them and use anything to grab the hole and pull them off. They just snap into place.
Old Sep 24, 2016 | 10:25 PM
Thang Nguyen's Avatar
Just use a flat screw driver wrap some electrical tape on the tip and pry them off.
Old Sep 26, 2016 | 05:21 PM
wa3ra's Avatar
Got a kid's toy suction dart around? Lick the dart tip, stick it on the cap, and, "pop!" the cap is off!
Diavolo
Sep 23, 2016 08:38 AM
Busa
May 14, 2016 05:49 AM
bullittandy
May 8, 2016 11:15 AM
Traindriver69
Apr 26, 2016 07:23 AM
revski666
Apr 5, 2016 05:42 AM
