How to take of rear headrests?
Old Dec 23, 2010 | 12:57 AM
04Xtype's Avatar
Question How to take of rear headrests?
I dont have the fold down rear seats in the car, and was wondering if there is an easy way to take off the rear headrests without having to take the seats out. I know some clips have to be replaced if the seats are removed, so trying to avoid that. Any input is appreciated.
Old Dec 24, 2010 | 02:00 PM
jjpopo's Avatar
There is a button on the escutcheon where the rods go into the top of the seat. On one side is a button that you push and on the opposite side is a slot where I use a coin to push in. I suspect that these actions release a captive mechanism that holds the headrest in place. When you do these two actions simultaneously, you will be able to pull the headrest out of the seat. It is a bit awkward to do but can be done. Hope this helps.
Old Dec 25, 2010 | 06:28 PM
Mike X's Avatar
Hi , like jj says , with a bit of brute force you can ease the rear headrests out with the seats in situ. Bit tight against the rear window but not too bad , just a case of pressing the release section on the collars that grip the shaft then easing them up while tilting them towards you .
Good luck ,
Mike.
Old Dec 25, 2010 | 11:01 PM
04Xtype's Avatar
Thanks for the adive guys, ill give it a try. I didnt think there was enough space to get them out, but will see if the cushioning will go in some and see if they come out.
Old Dec 26, 2010 | 01:06 AM
ant1.0's Avatar
drop the seats forward then remove!
Old Dec 26, 2010 | 12:03 PM
04Xtype's Avatar
Unfortunately I dont have the folding seats, so only option to fold down is to completely remove.
Old Dec 29, 2010 | 01:29 PM
04Xtype's Avatar
I ended up getting the headrests off w/o taking out the seats. As JJ and Mike said, just had to use some force to get them out. took about a minute for each one.
FrickenJag
Jun 16, 2025 02:15 PM
H20boy
Dec 24, 2024 03:23 PM
Nigels420G
Mark V - X 420G
Sep 17, 2015 10:29 AM
AtholC
Sep 9, 2015 09:07 PM
timm525
Sep 8, 2015 07:57 PM
