How would I program a transponder key
Old May 21, 2017 | 06:42 PM
Kyle Tice's Avatar
Default How would I program a transponder key
My gf has a xtype but has no spare key I can order a blank key with chip in it but do have to have the dealer program it or can I do it myself its just a basic key with no key fob
Old May 21, 2017 | 07:11 PM
Bud Tender's Avatar
The transponder is in the fob, not the key.
Jaguar X Type Information - Program Remote Key Fob
Important Note :-All the fobs that you wish to use Must be paired at the same time. Every time you operate the key as in step 5 above the code will be changed, previously programmed fobs will no longer work unless you pair them all at the same time.
Old May 21, 2017 | 07:20 PM
Kyle Tice's Avatar
Default This is what I want to buy no need for a fob
I dont need the fob just want a spare key it has the transponder in it Look at this on eBay http://www.ebay.com/itm/302320324758
Old May 21, 2017 | 07:29 PM
Kyle Tice's Avatar
I read the article if I buy 2new key fobs have them cut and then program them how it says they will start the car?
Old May 21, 2017 | 07:39 PM
avern1's Avatar
The x-type blade key mounted in the fob is the only one that will work with an x-type. They make single tibbey keys with the RFI in the key head but the Hertz is wrong for the car. Get the switchblade fob that is known to be compatible for your x-type.
Old May 21, 2017 | 07:42 PM
Kyle Tice's Avatar
So thats all no need is the fobs and can program em my self
Old May 21, 2017 | 08:50 PM
Dell Gailey's Avatar
To be very clear = the bottom portion (push buttons, door, etc.) can be programmed to operate any X type by following the programming directions found in this forum. The upper key portion contains the security transponder unit and must be programmed to your specific car by a Jag dealer that has the correct equipment.
Pairing fob =https://www.google.com/url?sa=t&source=web&rct=j&url=https://m.youtube.com/watch%3Fv%3DyJgp7bOGgns&ved=0ahUKEwj6ptTYuuHTAhVO-GMKHQ0XBfYQo7QBCBwwAA&usg=AFQjCNHjs9p1K1Wvl23dSy0c 2wMFCqRLkA&sig2=f4gO0Edxif3pFCJ3pX8pLw
Old May 21, 2017 | 09:38 PM
avern1's Avatar
Dell Galley is correct the transponders are dealer level software for programming. There are some keyshop/locksmiths that have the software.
