Hyper Flash Problem
Old Apr 27, 2015 | 11:32 AM
fenbers's Avatar
Cool Hyper Flash Problem
I installed LEDs for my turn signal lights (front, rear, side) knowing I'd probably have a hyper flash problem. I would have solved it by replacing the flasher relay to be LED-compatible, or would have added a load resister. As it turns out, I have no hyper flash problem on the external lights. I read this is because the flash rate is controlled by the GEM module, not a flasher relay. However, I do have a hyper flash occurring on my interior turn indicators (instrument panel). So without a flasher relay to replace, how do I revert the internal flash rate back to normal??
Mark
Old Apr 28, 2015 | 03:52 PM
Thermo's Avatar
Veteran: Navy
fenbers, you will need to install the load resistors to get the correct current draw on the turn signal circuit.
JarodL
Mar 7, 2024 01:39 AM
RonnieJoe
Dec 24, 2020 03:51 PM
TXJagR
Jun 20, 2016 01:02 PM
Mosers63
Sep 6, 2015 02:53 PM
joseph1945
Sep 5, 2015 07:12 PM
