I met a Genius...
Old Nov 25, 2007 | 12:41 PM
JP10501's Avatar
Default RE: I met a Genius...
hmm, noob question, what exactly would "kill" a transfer box ?
Old Nov 25, 2007 | 12:55 PM
Cadillac's Avatar
kill bill ?
Old Nov 25, 2007 | 04:33 PM
hankycbr's Avatar
mmm, another noob question. what is the transfer case? I thought the only thing i had to worry about my jag was the auto transmission?
Old Nov 25, 2007 | 10:12 PM
aquill1's Avatar
Transfers power to the wheels...or rather (only found in 4wd or awd) it takes power from the tranny and sends power to the 2 axles through gears...hmmm...let see what could I compare it to? It gives power to the driveshafts or through driveshafts turning gears to power the wheels to spin...I'm sure I'll be corrected with a better explanation...kind of like traction control our jags have...or rather dynamic stability control!
Hanky I just re-read your post were you serious or do you know what the transfer case is?
Old Nov 26, 2007 | 07:26 AM
hankycbr's Avatar
Hello Aquill,
no i was serious. I really didn't know what the transfer case is. I appreciate your thorough explanation and great picture as well.
do you have to change the fluids on the transfer case just like the transmission? how do you check for fluid levels?
Old Nov 26, 2007 | 12:30 PM
bigdreams05's Avatar
Is the transfer case like the differential?
Old Nov 26, 2007 | 04:03 PM
aquill1's Avatar
Not sure...I'd think we'd have both or its the same...the differential is what sends the power to our front/rear axles...and allows the shaft to drive the other 2 shafts...hmmm...anyone else help us...the more I think about it the more confused I get...
Old Nov 26, 2007 | 04:36 PM
billinohio's Avatar
differential is the place your axles come out of. transfer case is where tranny sends the power and then transfers 40%to front diff and 60% to rear, if I read the jag stuff properly
Old Nov 26, 2007 | 05:00 PM
aquill1's Avatar
Yeah thats what I thought...there are differentials on the car...
Old Nov 26, 2007 | 10:38 PM
JP10501's Avatar
so .. again, what exactly would cause the transfer case, differentials, driveshafts to fail/break/explode/die, etc ... ?
Old Nov 27, 2007 | 08:47 AM
tokaygecko's Avatar
ORIGINAL: JP10501
Fluid leak. There is little fluid to start; with a leak you wear out parts of the xfer case quickly leading to failure.
Old Nov 27, 2007 | 11:44 AM
aquill1's Avatar
Wouldn't the engineering of the drivetrain also cause it to be weak? Especially when our cars have nowhere near the power a stock evo lancer has and its awd? I say something jag did made this weak...perhaps not knowing a lot about it when planning to use awd on the x?
Old Nov 27, 2007 | 06:36 PM
jag_genius's Avatar
make sure you have a transfer case cooling duct. they brake off or people dont put them back when they do oil changes.
Old Nov 27, 2007 | 07:05 PM
aquill1's Avatar
Oil changes for the transfer case...I was picturing a regular oil change!
Old Nov 28, 2007 | 06:42 PM
jag_genius's Avatar
no .. it's a curved plastic air duct that bolt's to all oil pans.. it 's about 6 inches long.. and it covers the engine drain plug.
Old May 6, 2008 | 10:20 PM
hankycbr's Avatar
Hey Jag Genius,
should my 2002 x-type 2.5 liter have this transfer case cooling duct as well? I remember somebody even had a picture of one on this board but I can't find it? I looked everywhere on this site?
I clearly do not have one on my jag but I would feel better if I had one. Should there be bolts on my jaguar for this cooling duct?
Thanks!
