ID Part in Engine bay
Old Jun 12, 2022 | 02:40 PM
Tomjones's Avatar
Default ID Part in Engine bay
Hello ..
Can anyone tell me what this is ... I am hoping its the slave cylinder for the brake/Clutch...
but it does not look like the diagrams or pictures online
I tried bleeding it (brake pedal is going to the floor after taking out the ABS unit and putting it back)
Old Jun 15, 2022 | 11:38 PM
h2o2steam's Avatar
I see from your profile you have a 2008 X-Type with the 2.2 Diesel engine.
Perhaps one of the Diesel X members can weigh in and help you on this question.
It does look somewhat like a one way valve "check valve" of some kind, and with the plastic spike on the end it must just connect into a rubber grommet or attach to a tube.
What does it connect to and from?
Old Jun 16, 2022 | 05:16 AM
Cornerz's Avatar
@Tomjones I'm pretty sure there is an abs control until under the battery box. Probably worth taking that out to get a better view of where the pipe runs.
Old Jun 19, 2022 | 02:59 PM
gijoe50000's Avatar
Looks the same as a brake nipple. If it's connected to the brake system then it may be a way to bleed/drain the brake reservoir/pump..
oxendine
Jul 1, 2022 04:43 AM
AdamStudna
May 10, 2021 08:42 PM
my420
Apr 23, 2021 11:18 AM
JeffR1
Aug 31, 2013 11:51 AM
otto
Jan 30, 2012 02:47 PM
