Installing Alternator, do i need to remove Compressor?
Old Oct 13, 2010 | 10:32 PM
matl's Avatar
Default Installing Alternator, do i need to remove Compressor?
Hi I war reading through some posts to see if there was a howto for installing an alternator and someone said the compressor needs to be removed. its late and i havent looked under the hood but is this true? Any other things i should know? thanks
Old Oct 14, 2010 | 08:16 AM
Brutal's Avatar
ARE YOU SURE YOU REALLY HAVE A BAD ALTERNATOR? IVE SEEN MANY REPLACED ERRONEOUSLY WHEN BATTERY CABLES ARE THE PROBLEM WITH HIGH RESISTANCE, ESPECIALY WHEN THEY GET HOT AND THE BATTERY LIGHT COMES ON. tHE ONLY TRUE WAY TO CHECK IS RIGHT AT THE BACK OF THE POSTIVE CABLE STUD ON THE ALTERNATOR FOR CORRECT VOLTAGE
Old Oct 14, 2010 | 06:07 PM
matl's Avatar
The alternator is fuctioning property but one of the internal bearings has gone bad and it is making a heavy ratting noise. I looked under the hood and it does seem it needs to be dropped from the bottom, any way to remove it without opening up the ac system?
Old Oct 14, 2010 | 09:57 PM
Brutal's Avatar
remind me tommorow and Ill look, like ve said Ive NEVER done an alternator. Its 1 of the few things actually ppretty stout on the X
Old Oct 17, 2010 | 01:48 PM
matl's Avatar
Hi, Did you have a chance to look into that? Anyone else ever replaced the alternator? thanks
Old Oct 17, 2010 | 07:12 PM
SEBZX79's Avatar
Its a big PITA I tell you, I removed the compressor from my parts car this weekend and if you are looking to get to the alternator you will need to remove the compressor or your radiator and condensor.
dsnyder586
Dec 29, 2024 07:39 PM
Dicque
Sep 19, 2015 12:53 PM
jaguarbill
Sep 5, 2015 11:43 AM
Corycarlo
Sep 5, 2015 11:41 AM
d a
Sep 3, 2015 02:34 AM
