Intake manifold bolt issue
Old Jul 15, 2013 | 04:13 PM
ktag's Avatar
Default Intake manifold bolt issue
Hey guys,
So I've got a problem that the search function hasn't helped me with.
I removed the intake manifold on my '03 3L X-Type to change the manifold gaskets and as I was reinstalling it, I overtightened one of the bolts and the threaded brass part that it screws into popped out of its seat. Any ideas on a way to fix this?
The part seems to be in fine shape (except for not being int he engine anymore) and there isn't a ton of torque on those screws, so I'm thinking JB Weld could work, but I'd appreciate any advice I could get.
If it helps, it's the passenger side (US), back bolt, #5 according to the JTIS.
Thanks in advance.
Kevin
Old Jul 16, 2013 | 10:27 PM
Jeeves12's Avatar
ktag,
There are some very good 2 part epoxies with high temp attributes that will work. Sounds like you're going down that road. You can also try using a center punch on the plastic near the brass null. This will deform the hole and hopefully hold the brass null in place.
Good luck
Old Jul 17, 2013 | 06:51 PM
ktag's Avatar
Thanks, Jeeves!
So far the JB Weld seems to have held. I also have realized that there is space under the fuel rail (where the null sits) and, worst case scenario, I could replace the screw with a longer one and use a large washer to secure it.
I'll keep your center punch idea in mind, as well.
Thanks again!
toronadomike
Jan 22, 2026 10:13 PM
dsnyder586
Dec 29, 2024 07:39 PM
rusty37
Apr 5, 2020 07:40 PM
cissdm
May 3, 2016 06:02 AM
al_roethlisberger
Sep 11, 2015 10:04 PM
