interior hid replace
Old Dec 10, 2014 | 07:22 AM
manuelm768's Avatar
Default interior hid replace
Quick question. Are all the interior light bulbs the same size? I want to replace them with some hid ones. Thanks guys
Old Dec 10, 2014 | 05:12 PM
Thermo's Avatar
Veteran: Navy
manuel, the bulbs in the interior are a few different sizes. With that being said, I think you are mis-speaking as to what you are after. Are you after HID lights inside or are you after LED lights for the inside? Big difference. Most of your interior bulbs are down in the 5 watt range and put out minimal light (except for the overhead dome lights, but those are only 20W bulbs as it is). The smallest HID bulb for vehicles I know of is a 35W bulb that would output about 10 times what the overhead lights would put out. So, it would be way overkill for what you are after.
If you are looking at LEDs, that is a different story. I would say to check out a website like that for Sylvania Lighting and see what they have in the way of bulb listings. from there you can do some looking around and seeing what you can find. If you are after some LED light fixtures, let me know. I can give you some feedback of what I have experienced with LED bulbs and what to look for and what to avoid.
Old Dec 10, 2014 | 08:01 PM
manuelm768's Avatar
Ok thermo thanks. I think led is the way I want to go then. I seen a video on youtube with a x type interior light bulbs changed to a bright white which I loved. Im looking into changing the map light, dome, door,
Old Dec 11, 2014 | 10:44 AM
Thermo's Avatar
Veteran: Navy
manuel, take a look at: 2X 9W Aluminum T10 Festoon Car Dome Reading Interior COB LED Light Lamp White Q1 | eBay
I installed these in my car in the two dome lights and my interior is very bright now. THinking about installing these into the map lights too. They are "plug and play". So, no modification is needed and they simply plug into the factory bulb base. The big thing you need to keep in mind is that the plug needs to be orientated correctly, otherwise the LED will not light (polarity sensitive).
Old Dec 11, 2014 | 11:13 AM
manuelm768's Avatar
Ok cool this is exactly what I want. My plan is too change out the dome, map dome, underfoot, and the ones on the bottom of the door. Will all the bulbs be the same size?
Old Dec 11, 2014 | 12:48 PM
91stealthes's Avatar
This should have all the information that you need, as well as instructions on how to do it.
https://www.jaguarforums.com/forum/x...eds-how-58115/
JarodL
Mar 7, 2024 01:39 AM
Sprayall
May 30, 2021 08:13 AM
rudelover2
Sep 11, 2015 08:53 PM
Sprayall
Sep 3, 2015 07:49 PM
laserguy
Sep 3, 2015 02:02 PM
