Interior power outlet
Old Dec 20, 2013 | 02:06 PM
Fezz's Avatar
Default Interior power outlet
The power outlet under my radio seems to be really loose for some reason. It doesn't want to connect to a car charger. The lighter knob works, but the little effer ejects out and flies far. How would I get about fixing this little problem? I haven't disassembled the interior too much except for the dome lighting.
Old Dec 20, 2013 | 03:04 PM
Thermo's Avatar
Veteran: Navy
Fezz, from what you are describing, it sounds like the clear plastic ring around the lighter is broken and that is allowing the socket to move freely. Doing a little bit of looking, a new cigarette lighter will cost you about $60 (requires buying the whole ashtray). May want to double check with the local dealership on that just to make sure. Maybe you can get just the lighter assembly itself for a little bit less.
kevinl
Oct 31, 2019 06:15 PM
Mbourne
Sep 14, 2015 09:21 PM
John Fox
Sep 12, 2015 12:20 PM
1964Daimler
Sep 9, 2015 11:28 AM
King Charles
Sep 3, 2015 12:40 AM
