Intermittent starting issues on jag 06 plate x type 2.5 petrol model
Intermittent starting issues on 06 x type 2.5 petrol.
1: seems to be in the mornings or after car has been sat for a while but no rhyme and reason as to why.
2: takes a few go’s to start when problem is there. Makes a loud clunk before start and displays cruise not available on screen below speedometer.
i have replaced the battery and done nothing else. Any suggestions and the video is below.
thanks in advance for any assistance.
thanks for your reply.
yes I can hear it hum.
could it be spark plugs?
Use a scanner via the OBD port and smart phone with the Torque app to see the fuel pressure when the no-start situation occurs. Fuel pressure should be around 3 bar (330 kPa) with the ignition in the ON position prior to engaging the starter. If the pressure is less than roughly 3 bar, the fuel pump is failing and should be replaced.
Thanks for your replies guys.
car is booked in at a mechanic next Thursday as he will keep car in overnight on weds to see what this issue is.
if it is fuel pump any ideas on what the damage may be cost wise?
slojotaa
F-Pace (X761) / C-X17
Jun 3, 2016 06:19 AM
joebow8
Mar 1, 2008 08:24 PM
