Jag xtype 2003
Old Jun 22, 2018 | 09:17 AM
deloralie's Avatar
Default Jag xtype 2003
My battery was drained a few times i just replaced with a new battery. I have noticed that when the car is turned off i can hear a very low humming noise from around the steering wheel or the dash,,,what could that possibly be and could it be draining my battery?
Old Jun 22, 2018 | 11:11 AM
Bud Tender's Avatar
Aspirator for the climate control system. it shuts off after a while.
Old Jun 22, 2018 | 05:07 PM
avern1's Avatar
+1 aspirator fan. It coes on when you open the door andd shuts down about 15 minutes after you exit the car.
Take a close look at the ignition switch. There should be a small door covering the hole where the key inserts. If it sticks open then the electronics will not power down.
You can also take a cell phone on put it on video and shut it inside the trunk and glove box to insure thhe lamps are powering down.
Old Jun 22, 2018 | 06:38 PM
Dell Gailey's Avatar
Default Quiescent power drain on Jaguars
Good read
File Type: pdf
M. Rockatansky
Oct 11, 2016 12:45 PM
Blondie 1
Oct 1, 2016 01:02 PM
JimC64
Apr 16, 2015 08:27 PM
JimC64
Feb 13, 2014 07:35 PM
sjuraud
Aug 28, 2010 02:11 PM
