Jaguar X400 Diesel fails to crank
Old Apr 5, 2022 | 06:02 AM
Richard Manser's Avatar
Default Jaguar X400 Diesel fails to crank
Yesterday my 2009 diesel X400 suddenly decided not to start. Turned key but nothing happened; no solenoid, no dimming light etc. After some time I decided to give the fuel emergency cut off valve a push; after that everything started as normal. The diesel does no have an electric fuel pump to shut off and investigation of the wiring diagrams are not very helpful in showing what this switch does inhibit. I however today decided to disconnect this switch and it produced the same symptoms. I have now ordered a new switch in case the same thing happens again.
Old May 1, 2022 | 11:46 AM
Fault now fixed. When the fault is present there is no continuity from F34 in engine fusebox to ground. This was caused by a "dry joint" on the starter motor.
Old May 2, 2022 | 04:35 AM
h2o2steam's Avatar
Well, there is dry ............and then there is downright arid!
Good find Richard.
Old May 2, 2022 | 04:53 AM
The pain in the butt was having to completely remove the starter motor to find and fix it.
jean HJ
Jan 22, 2022 12:37 AM
scrappydoo
XF (X260)
Apr 30, 2020 10:05 AM
Mr5000
Oct 10, 2016 09:32 AM
tonys
Jul 22, 2012 04:32 AM
BurgXK8
Jul 17, 2010 10:20 AM
