Jaguar xtype help Code p2097
Old Mar 11, 2019 | 03:17 PM
Jayson Duble's Avatar
Default Jaguar xtype help Code p2097
So i own a jaguar xtype awd. 2004 model.
I recently received a code p2097, assuming that's the downstream sensor.. I just bought a new senor but I cant find the location to install it.. where is it located ?
anyhelp would be awesome.. I tried to find the help on the forums and I just dont understand if I have two cats ? Or 1 etc and there locations..
Jayson
Old Mar 11, 2019 | 03:21 PM
car5car's Avatar
Jayson
If you have steering wheel on left side, you have 2 cats, if on right side (and have funny accent), possibly one.
There are a few more ways to find out. If you have hood, then 2 cats, if bonnet, you have possibly one.
Old Mar 11, 2019 | 03:41 PM
Steve M's Avatar
I have a steering wheel on the right, a funny accent, a bonnet and 2 sensors!
You have to peer over the back of the engine to see the sensors, pig to get at.
Old Mar 11, 2019 | 03:52 PM
So how do I know which senor to replace and where are the sensors located I have a 3.0 v6. Left hand steering wheel
I'm in the USA.
Anyway
The code was post bank one. When I look under the car I only saw 1 exhaust pipe split into two out the back
Old Mar 11, 2019 | 05:23 PM
I figured it out the o2 sensor is located between the firewall and the mid bottom half of the engine .. right side if you facing the engine from behind .. has anyone replaced this sensor before... ? How did you do it.. I have the ALL data on it and its seems impossible.
Jayson
Old Mar 11, 2019 | 05:52 PM
JaguArvid's Avatar
Jayson
get a breaker bar and an oxygen sensor removal tool suggested by thermo (pictured), I did it by removing the smalll bracket where the connections for the o2 sensors are fitted, gave me enough space to bring the breaker bar in behind the engine.
Old Mar 11, 2019 | 05:56 PM
Dell Gailey's Avatar
Or if you REALLY want help, instead of just posting where, how, why.....?
Use the search tab on the main X page where there are DOZENS of explanations and pictures and tools to use.
Search is a marvelous tool.
ontarioKel
Aug 8, 2017 01:44 PM
Joe Walma
Aug 3, 2017 05:50 PM
seanariel
Feb 12, 2014 09:50 PM
magicjuan17
Jan 24, 2014 11:36 PM
