key/ignition set...
Old Mar 13, 2015 | 08:31 PM
Razorback31's Avatar
Default key/ignition set...
I found a type 2003 I think that has a lost key. CN I but an ignition set (key and ignition) and swap it out to fix it?
Old Mar 13, 2015 | 08:35 PM
Dr dome's Avatar
To swap it out you need the computer, The ign switch and the speedo Cluster. It all works together.
The Dr!
Old Mar 14, 2015 | 08:55 AM
mrplow58's Avatar
Call around to locksmiths in your area. The good ones will be able to cut you a new key, and will have the whole remote set up. I got my spare key and remote for less than half of the $508 that the ******* wanted to charge me. The parts guy sent me to this guy. Jaguar changes it's codes every 90 seconds, so you will need to find someone with the right equipment, or are satisfied with using just the key for the doors......Good Luck....Mike
Jimmysea
Feb 24, 2015 01:41 PM
Staatsof
Apr 6, 2014 07:40 AM
domer94
Feb 27, 2012 10:34 AM
happilute
Mar 9, 2008 01:15 PM
