Key Less Entry Programming
Old Feb 6, 2017 | 03:57 PM
carlosvela1520's Avatar
Default Key Less Entry Programming
My Remote just went dead. Probably no longer programmed. Will I need it to turn on the car? I don't have the car near me now to check.
Old Feb 6, 2017 | 07:53 PM
motorcarman's Avatar
I uploaded HUNDREDS of TSBs to this site and these are among them.
Read through as many as you can and you will understand your car and it's faults.
bob
Old Feb 7, 2017 | 10:39 AM
I opened the remote transmitter and found that it was really dirty. I replaced the battery and while the transmitter worked the drivers side door would not open. All other doors opened fine. I used the key to open the drivers side door and it would not open. I turned the key back and forth several times and jimmied the door handle until it opened. I am afraid of breaking something. I have been opening the door through the passenger side. I'm thinking now that the door locking mechanism is not working properly.
Old Feb 7, 2017 | 11:38 AM
avern1's Avatar
First I would try a good spray lubricant into the locking mechanism. If that doesn't resolve the issue then try the link listed below.
As a last resort you made need a new locking mechanism if the solenoid is not working.
https://www.jaguarforums.com/forum/x...oor-faq-48827/
Old Feb 7, 2017 | 11:35 PM
After much fiddling around I realized that if I turn the key to the left and leave it turned for a couple of seconds the door unlocks. I was trying to use it like a regular key. Im not sure if that is how the unlocking mechanism works or if it is just taking a little longer to engage. Either way I can get in through the drivers door. I just ordered a new remote transmitter and found a local locksmith to activate it and cut a new key. I checked with the dealer new key and transmiter $1000. Yikes
