Leak under trunk
Old Jul 13, 2014 | 02:58 PM
sarahsmi's Avatar
Default Leak under trunk
Hello,
I recently used my spare tire. After it's use I put it back in the trunk and now I am noticing a grease leaking from under the trunk area. Not sure if the leak is related to the spare tire or not. (The picture shows 2 spots on the floor because I moved the care yesterday) Can anyone advice me? Thank you.
Attached Thumbnails Leak under trunk-kindle_camera_1404138219000.jpg   Leak under trunk-kindle_camera_1404138223000.jpg
Old Jul 13, 2014 | 07:49 PM
Thermo's Avatar
Veteran: Navy
Sarah, not to ask a silly question, but do you store other stuff in the well with the spare tire like a quart of oil, some brake fluid, etc? Odds are, if you do, you managed to get one of those bottles pinched between the tire and the sheet metal and you are getting some fluid out of the bottle. What you show as leaking is nothing more than a drain for the spare tire well so if your trunk seal fails, the water will not build up in your trunk. Probably best to remove the spare tire and see where you are getting the fluid from.
Old Jul 14, 2014 | 09:58 AM
sarahsmi's Avatar
Thank you Thermo!!!!!
Apparently, when the guy replaced my spare, there was a bottle of Armor ALL Protectant in there that was crushed and subsequently spilled. Go figure! So happy to know that it was nothing major at all. Thank you for your help.
Rivguy
Dec 4, 2020 07:55 AM
martybmw
Apr 2, 2016 04:55 AM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
al_roethlisberger
Sep 9, 2015 09:14 PM
prettydaim
Sep 7, 2015 05:16 PM
