LED replacements
Old Feb 2, 2016 | 10:10 PM
hlgeorge's Avatar
Default LED replacements
Among the many things I'm doing to my car(new to me), is changing the tag, boot and interior lights to LED. Did the Boot & tag and was working on the front overhead console. Dropped it down easily to find the bulbs are in the most stupidly designed bulb holder![C2S002298] Started with the passenger reading light and BROKE IT! Little metal socket clamp broke off. Has anyone ever taken the lamp holder out? I tried a few times, but was afraid I might break it too. If I could get it out, I'm sure I could retrofit a new lamp socket. Sometimes I wonder what the engineers were thinking when designing this! The rest of the lamps look easy to do. Any help or ideas appreciated.
Old Feb 2, 2016 | 11:46 PM
wa3ra's Avatar
Are you adept with a soldering gun? Use stiff, insulated copper wire (think a tiny chunk if 12-gauge), solder to the broken tab, then solder the led to the wire. The likelihood that you will ever need to replace the LED is slim.
Old Feb 3, 2016 | 12:51 AM
hlgeorge's Avatar
Yes I can use a soldering gun. Just need to get the holder detached from the roof!
Old Feb 3, 2016 | 07:37 AM
avern1's Avatar
Attached is a sheet showing the pry points on the model thru 2004. I doubt it will be much different on yours. Once it opens up you can then unplug and unscrew it from the overhead.
File Type: doc
Old Feb 3, 2016 | 02:19 PM
hlgeorge's Avatar
That doesn't work for me. The console pulls down and the lamp holder is still attached to the roof. The lamp holder is the part that I need to remove. Part #2 is the part I need to remove.
jagnew
Jul 22, 2017 07:45 AM
TR64ever
Feb 5, 2016 10:21 PM
David7
Jan 18, 2016 06:58 AM
BlkCat
Jan 13, 2016 04:59 PM
Leeper
Jan 12, 2016 12:46 PM
