Limp mode with red ! stuck in high gear
Old May 19, 2026 | 01:41 PM
Ronks2's Avatar
Default Limp mode with red ! stuck in high gear
Car has been sitting all winter, but looking to get back on her now that warm weather is here.
She is a 2006 3.oL auto with ABS and DSC and intermittent codes after she warms up.
General consensus is cold solder in the ABS board. I am having trouble finding a replacement locally. WIll try and pull it down for repair.
Car is stuck in limp mode with the red !..
IF I hook up my laptop with the old JLR software to the car can I turn off DSC, or tell the car not to look for it? Basically over ride the error.
The other question would be if I start it up and the lights are not on, can i hold down the dsc button to shut it off prior to it getting hot and throwing the error?
Thanks guys
Old May 20, 2026 | 11:13 AM
dh53's Avatar
Wheel speed sensors OK? A bad wheel speed sensor can give the ABS warning. If you have 2 wheel speed sensors out the speedo won't work. Those sensor codes are C11xx. Chassis codes and not powertrain codes.
There are plenty of places online that advertise repair for ABS circuit boards. I almost pulled the trigger on using one recently (for a Toyota, not the Jag) but found the correct ABS at a junkyard for less than the repair quote.
Old Yesterday | 08:02 PM
Peter_of_Australia's Avatar
My suggestion would also be aiming at the wheel spend sensors, but in a different way (yes the sensors themselves could also be buggered, but that's not that likely):
It is likely that the signal from the wheel speed sensors (maybe just not from 1 sensor) does not get thru to the ABS module.
It may be damage wire, or more likely a corroded connector-contact, There is a connector at the sensor, and a well hidden connector behind the wheel arch liner. and then the wires go to the big blue connector on the ABS module. Even there could be a contact problem with the pins (I had than - that was ridiculously difficult to find - I replaced one of the pins in the big blue.)
SEE:
https://www.jaguarforums.com/forum/x...sensor-199510/
ALSO: You might have cold solder points for the power supply in the ABS module. It is possible - even if quite difficult - to remove that module, to force your way thru to the solder points and re-solder them. There are youtube videos about that.
And another possibility: Dirt in the "trigger-sprocket" for the sensor, but also not that likely.
zidjan
Feb 24, 2016 11:42 AM
Sev
Aug 24, 2014 10:00 PM
wheelmang
Mar 27, 2014 06:59 PM
jagxk2008
May 4, 2013 12:19 PM
