little annoying noise coming from right side of stiring wheel?
Old Jul 5, 2010 | 08:11 PM
maikal_0011's Avatar
Default little annoying noise coming from right side of stiring wheel?
i read on of the post here about the same problem, when i turn of the car, it makes the tiny noise in tiny went between wheel and radio/a/c control system
now some people posted here that it's normal and it should go off after 30 seconds, it doesn't,
every time i get in, it makes noise, and even if i close the door and i am inside doing nothing it still makes noise
it's getting annoying after while
what do u guys think of that
Old Jul 5, 2010 | 08:26 PM
Pacobell's Avatar
Default Annoying little noise
I don't hear anything coming from behind the dash when I turn my X-Type off except the dampers of the ventilation system closing if the A/C was on (which it usually is this time of year in FL). The only peculiar noise I've heard behind the dash is a strange buzzing noise when I accelerate moderately from low speeds. It only lasts a second or two and goes away. However, after about 2 years, it rarely has come back. Nothing else is acting strangely, so I can live with the weird noises. I will pay more attention now that you mention it to see if I can detect something similar as you have mentioned when I shut off my car. Good luck.
Old Jul 6, 2010 | 04:38 PM
rothe's Avatar
https://www.jaguarforums.com/forum/s...ead.php?t=5915
Scroll to "buzzing behind dash"
Old Jul 6, 2010 | 07:49 PM
rothe is spot on maikal
Old Jul 6, 2010 | 08:15 PM
that helped little bit
after shutting the car off and i am sitting inside turning off everything, it stays on forever and ever
i thought it was parking sensors warning, it's like when u r backing up and if there was any object close to the back of the car and then that tiny went makes noise
i saw that on youtube, some guy was trying to show how fast his car goes, and he was backing that tiny went started to make noise here:
http://www.youtube.com/watch?v=-j2--...eature=related
look at 0:23-0:24
so i don't what is causing it but i think it has to do with sensors according to video , i THINK
Old Jul 8, 2010 | 03:51 PM
sidewalkman's Avatar
OK, to make it clear, it's supposed to make the noise, it's normal.
BrentGardner
29
Dec 16, 2024 12:13 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
lee,lee
Aug 31, 2015 04:35 PM
Sshenton1975
Aug 30, 2015 09:29 AM
souldoubt
Aug 25, 2015 08:15 PM
