location of cylinder #2
Old Sep 20, 2014 | 08:31 PM
helpfixjag's Avatar
Default location of cylinder #2
I have a 2002 Jag 3.0 x type. It's codes are p300, p302, 1314, 1316, 1000. After reading a lot of threads I replaced the coil and spark plug I thought was # 2. looking at the engine I replaced the coil on the front side closes to the belt on drivers side. I still have the same problem and after reading more threads I am unsure if I replaced #2 or #6. can anyone please clarify cylinder numbers for me. Thanks
Old Sep 20, 2014 | 09:35 PM
dwclapp's Avatar
Cylinders 1, 3 & 5 are on the firewall side. Cylinders 2, 4 & 6 are on the radiator side.
1 & 2 are closest to the serpentine belt - the "front" of the engine.
5 & 6 are closest to the battery.
Old Sep 20, 2014 | 09:43 PM
helpfixjag's Avatar
that's what confuses me. the battery and belt are both on the drivers side. I would call the belt side the front of the engine. is it 1 from front of engine on firewall side and 2 driver side front near belt under air box closest to pcv hose and air box intake?
Old Sep 20, 2014 | 09:48 PM
helpfixjag's Avatar
Sorry. Just looked again and the belt is passage side. my mistake. answers my question. Thank you for replying.
Old Sep 20, 2014 | 10:16 PM
dwclapp's Avatar
No problem. For a moment, I thought you were referring to the skinny belt next to the battery. That's for the water pump.
The "front" of an engine is always where you'll find the serpentine belt and timing chain(s) or timing belt(s). On our Jag's you can see one of the two timing chain through the hole were you add oil to the engine - on the US passenger side. The "rear" of the engine bolts to the transmission - on the US driver side.
This thread has a picture and diagram of the cylinder numbers (towards the bottom):
https://www.jaguarforums.com/forum/x...n-coil-125810/
Old Sep 20, 2014 | 10:20 PM
helpfixjag's Avatar
Thank you dwclapp. just confirms I replace wrong one. I will correct in the am and update.
Old Sep 20, 2014 | 10:55 PM
dwclapp's Avatar
Nothing to be embarrassed about. It would be much easier if the auto makers stuck to an industry convention for numbering cylinders. But they don't, so even veterans need to double check a reference, particularly when working on multiple engine brands.
kthrash
Feb 25, 2019 10:20 AM
JAMES1944
Sep 29, 2015 11:58 AM
42Ajd
Sep 26, 2015 07:04 PM
redgear
Sep 26, 2015 07:21 AM
vacolorito
Sep 25, 2015 09:29 AM
