Looking for a part or part number if someone can help....
Old Jan 10, 2014 | 08:38 PM
nilosjag's Avatar
Exclamation Looking for a part or part number if someone can help....
My water pump
OES Genuine W0133-1826500 Accessory Belt Tensioner has melted but I dont want to buy the whole assembly just would like to get the pulley does anyone no how to get this item without buying the assemble, part number vendor anything would be a great help. Any clues to this would be great to me, maybe somebody has one they want to sell in good shape but would prefer a new pulley. 2003 X-type 2.5. Thank you for your help..
Old Jan 10, 2014 | 10:59 PM
AlfaVeloce's Avatar
I have one, pretty sure. Not new but in very good condition. I guess you are talking about a pulley, no bearing, no tensioner? Post or PM me a picture of the part you are looking for to be sure.
Old Jan 11, 2014 | 08:27 AM
Thermo's Avatar
Veteran: Navy
Nilo, I would say to pull the tensioner off of the car, remove the pulley that you want and then go to your local auto parts store and see what they have. Tell them to start looking at the pulleys for either a 3.0L motor for the Lincoln LS or for the 2.5L motor on a Ford Focus/Fusion. One of those pulleys may match up.
Granted, for the amount of time that you are going to spend, Partsgeek.com has a whole tensioner assembly for $46 (plus S&H). Just something to think about. How much is your time worth?
Old Jan 11, 2014 | 01:41 PM
nilosjag's Avatar
Hi the part looks like the link below but with out the tension arm just the pully that fits on it..
OES Genuine Acc Belt Tensioner Assembly for select Jaguar X-Type models : Amazon.com : Automotive OES Genuine Acc Belt Tensioner Assembly for select Jaguar X-Type models : Amazon.com : Automotive
Old Jan 11, 2014 | 04:30 PM
AlfaVeloce's Avatar
Well I am Mr. Disappointment today. My extra one is no good. It might work but the bearing doesn't feel "smooth". And if it gets hot, then you are right back in the melted pulley business. I tried to press out the bearing and replace that, usually pretty easy to do. I did all the serpentine idler and tensioner pulleys and it worked great and was super cheap to do. But the plastic on this one is melted around it on both sides to hold the bearing in. It came out, but broke out a thin ring of plastic as the bearing came out. I can try to put a bearing in it and re-melt the plastic to hold it in if you want to try that. I'd do it on my car and never look back. I don't know how much a bearing costs but I'll find out and let you know. But honestly you might be more comfortable just buying the one from partsgeek as Chris suggested. Also look at car-parts.com for a used part, or I've had pretty good luck with RockAuto.com for new parts (they'll both be selling a whole tensioner). However, Rock Auto did fail to get me proper serp belt tensioner, which led to the bearing replacement deal that turned out a couple of orders of magnitude cheaper than replacing the whole pulleys anyway.
That one you linked to on Amazon, $50, free shipping... that's going to be hard to beat.
Old Jan 12, 2014 | 07:48 AM
nilosjag's Avatar
Thank you for your help. I am going to order the one from amazon seems the easiest thing to do at this point..
Old Jan 12, 2014 | 05:52 PM
AlfaVeloce's Avatar
I agree on that probably being easiest. Good Luck. Let us know how that works out (always looking for good sources).
philwarner
Oct 4, 2024 01:37 PM
Wolfy
May 28, 2024 08:06 AM
Doug
Feb 27, 2019 01:31 AM
Tar
Sep 6, 2015 11:24 AM
Busa R
Sep 3, 2015 05:01 PM
