loud clunking noise
Old Jun 2, 2011 | 02:31 PM
satwarez's Avatar
Default loud clunking noise
2002 x type automatic 2.5 v6 awd :was experiencing loud clunking noise as ai drive. After close inspection i discovered that it was the drive shaft bearing. Can the drive shaft bearing at the front be repaired , or would i have to replace it with a different. thanks in advance.
Old Jun 4, 2011 | 03:29 PM
Adam Lueb's Avatar
Smile Clunk
I believe it can, most bearings can be replaced one way or another. I had the same clunk in my 03 2.5L. I also thought it was the drive shaft. Turns out the Jaguar dealer told me it was the bushings for the front and rear sway bars.The wanted over $800 to fix, my neighbor who is a Ford mechanic did it for $200 plus the cost of the bushings, so $250 all together. He said they were a challenge but no more clunk. The drive shaft was OK. Rub some grease, thick grease on it, if it doesn't go away then it is the bearing, if it goes away check the bushings.
JimC64
31
May 30, 2016 03:04 PM
redxk8
Oct 4, 2015 08:28 AM
inactualis
Oct 2, 2015 11:13 AM
baskervillema
Oct 1, 2015 06:43 PM
Gregory Neil O'Rear
Sep 29, 2015 09:52 AM
