Lower Mesh grill
Old Jan 17, 2008 | 06:46 PM
jvegas's Avatar
Default Lower Mesh grill
I have a 2003 X-Type. I replaced the top grill with a chrome mesh one. I just had the bottom grill done by someone and I noticed a small gap on the top of the lower grill. Has anyone had this problem?? or have any tips?? thanks
Old Jan 17, 2008 | 06:51 PM
FactoryJaguarTech's Avatar
Default RE: Lower Mesh grill
Put it on correctly. J/K
Is it factory lower or aftermarket? The only aftermarket grilles I would recommend would be from Arden. Fit like a glove everytime.
Old Jan 18, 2008 | 08:46 AM
RedJag's Avatar
I've got the same issue, about a 1/8" gap on the top driver's side of the lower mesh grill. (It's factory and I put it in correctly.....)
Old Jan 18, 2008 | 02:15 PM
jvegas's Avatar
It is factory.. It was installed the right way. I have that same gap on the top drivers side. Hey, RedJag is your clips on the top of the grill toward the center or toward the outside of the grill? I am starting to think maybe the grill is on upside down. Think that maybe it???
Old Jan 18, 2008 | 06:33 PM
an 1/8 inch is pretty small. Maybe it is within factory tolerance?
Old Jan 18, 2008 | 06:42 PM
Size:  6.3 KBName:  X6JYMSAAB5.jpg
Size:  6.1 KBName:  AudiX6JYM-2.jpg
ORIGINAL: FactoryJaguarTech
I hear what you're saying FJT.........but to someone who is really **** about their cars ( that would include me to a degree I guess .....lol ) that would be a lot?
Jim
Old Jan 18, 2008 | 11:08 PM
jvegas's Avatar
1/8th of an inch I could deal with. mine has about a 1/2 inch gap! most people don't even notice it but I do.
Old Jan 20, 2008 | 09:16 PM
RedJag's Avatar
Pulled mine off again today and put it back on per the instructions...I had done it right the first time, it only goes on one way. Now it has about a 1/4" gap all the way across the top....more uniform anyway...still looks good. Since I'm using the black one,I will likely slit some black tubingand run it across the top.
Old Jan 27, 2008 | 12:21 AM
jvegas's Avatar
what i was wondering is this, there are two sets of clips. a set on top and a set on the bottom. one set is closer to the center of the car then the other set. are the more centered clips on you grill on the top, or the bottom?
Old Jan 31, 2008 | 10:43 AM
gotti15's Avatar
I just purchased the lower mesh grille from JaguarXP and it looks like a pretty simple install. Are there any FAQ's on installing it? I have a 2002 X-Type and the only thing I'm concerned with is removing the diffuser. Do I need to drill or cut some pieces? Hopefully, its just the basic removing some screws.
Any advice?
Old Jan 31, 2008 | 10:58 AM
jvegas's Avatar
not that i know of. the problem is the damn gap at the top. i see some people have glued theres on instead of using the clips, which I would not do. did it come with directions?
Old Jan 31, 2008 | 11:27 AM
ArdenX's Avatar
You have two options in regards to the lower grille assembly.
The first is to take off the front bumper cover and do it properly (I'm not sure if JaguarXP's install instructions detail this procedure).
Or the second option is to try and assemble with the bumper cover on and be disappointed with the results. If you ever see any pictures where someones lower grille looks totally jacked up or skewed out of proportion it's because they attempted the install without removing the bumper cover.
Old Jan 31, 2008 | 01:00 PM
gotti15's Avatar
Thanks ArdenX. Now my next question, any tips on removing the front bumper? Or should I just bite the bullet and pay local body shop to install it for me?
Old Jan 31, 2008 | 01:35 PM
jvegas's Avatar
if you pay the shop the will charge you for about2-3 hours of labor (jagtech will know the time for sure) if you don't mind paying then go for it. I did.
Old Jan 31, 2008 | 05:00 PM
Jvegas.......If you're gonna do the mesh grille ( which loooks fantastic btw) do it properly and not half assed. You 'll only have to look at it and regret it every day thereafter[&:]
Jim
Old Feb 1, 2008 | 09:04 AM
RedJag's Avatar
Here's mine. OEM lower grill (not from jag XP) unless I'm bending down looking at it you can't see the gap across the top. BTW the factory lower grill does not require removal of the bumper cover which is nice.
[IMG]local://upfiles/2846/221EEA0541A444C09C75A1B635F49208.jpg[/IMG]
Old Feb 1, 2008 | 09:08 AM
jvegas's Avatar
i have the mnesh grill already. it is oem but that gap drives me nuts. i need to knoe about the clip question i asked about in this thread.. can anyone help?
Old Feb 1, 2008 | 04:47 PM
gotti15's Avatar
I'm going to take mine to a body shop, I dont wanna f' up my bumper
Old Feb 1, 2008 | 06:08 PM
jvegas's Avatar
hey gotti let me know where the clips are placed. read above posts. thanks
Old Feb 1, 2008 | 08:13 PM
RedJag's Avatar
JV - don't knowI this helps you, but here's a photo of the one I have. The top has the three close clips, the bottom has the more spread out clips.
[IMG]local://upfiles/2846/AEE4F8CA36294F39A50C670245A5D95B.jpg[/IMG]
