This may be the final post..
Old Oct 16, 2010 | 08:19 PM
Disco stu55's Avatar
Well shes running better, a bit, but any ideas ont eh noise i described earlier
Old Oct 18, 2010 | 06:33 AM
The Chris X's Avatar
It could just be your injectors pulsing, this is normal. Have you ever replaced your IMT o rings? Does the ticking change with engine RPM?
Old Oct 18, 2010 | 02:18 PM
No I havnt, how do I got about doing that and how much, also theres a tube by that area that is prone to cracking too i hear.
Old Oct 18, 2010 | 02:19 PM
And i got a check engine light again, and my gas milage is going down
Old Oct 18, 2010 | 07:47 PM
I <3 X-Type's Avatar
The IMT o-rings would be a must. They are the quick fix to some the codes your seein. They are located right where your hearing the noise, the passenger side of the intake. They are two black circle shaped discs. It has two bolts holding them in. Simplly unbolt them and pull it out, you will see a dried out cracked yellowish o-ring, causin the vacuum leak. Local Jag dealer sells them for a couple bucks each. Easy cheap fix!!! And takes about 10 min. Although i did mine when i did my plugs cuz i was told the intake needed to come off to do the bottom but apparently you can slip the o-ring over the disc. Can try it.
FYI.....the new o-rings should be GREEN. They are the new improved ones. GOOD LUCK!!!
Old Oct 18, 2010 | 08:44 PM
Okay, yea i looked them up on the forums, there about 7 bucks, i dont have a local jag dealer, do you think any auto store would carry them cuase we got a few of those
Old Oct 18, 2010 | 09:20 PM
H20boy's Avatar
If you're too far away from a dealer, just call Dan at Nalley Jaguar, I bet he'd sell you the o-rings, put them in a #10 envelope and mail it to you...at no shipping charge. He's a good guy to deal with on parts.
Old Oct 18, 2010 | 09:44 PM
  #28
he dosent ship canadain unfournatly
Old Oct 18, 2010 | 09:56 PM
Honestly....If you could match up the o-ring size i really dont think it matters. Its just an o-ring. So if you can get one from someone nearby check it out. I think its roughly 3". Let us know.
Old Oct 19, 2010 | 11:15 AM
  #30
Okay i will, I wont be able to get around to it till the weekend, Im drowning in homework again. What about vacuum leaks, where are the most common ones?
Old Oct 19, 2010 | 11:54 AM
  #31
H20boy's Avatar
my bad disco, didn't know Red Deer was a canadian city...
Old Oct 19, 2010 | 12:17 PM
  #32
kmwolf's Avatar
I ordered the o rings from my local Napa store here in ND.
Old Oct 19, 2010 | 12:19 PM
  #33
sidewalkman's Avatar
Alberta, so it's only sort of part of Canada.
Old Oct 19, 2010 | 04:57 PM
  #34
The IMT 0-rings is one of the MOST common vacuum leaks brotha. Thats why its mentioned. Also the vacuum line running from the brake booster and the one that runs north and south to the left of the air intake tubes. Ill try and find pics.
Old Oct 19, 2010 | 05:09 PM
  #35
Heres a link to a pic of the IMT o-rings.....
https://www.jaguarforums.com/forum/sh...6&postcount=16)
The other is the 8" tube running along side of the intake suction ending at the air filter box. If you go to the FAQ part you will see one under engine that says soemthing about vacuum leak. It shows a pic of this tube.
jimforrest (uk)
Feb 28, 2019 06:42 PM
rhemler
Oct 4, 2015 05:37 PM
baskervillema
Oct 1, 2015 06:43 PM
Glenn Barickman
Oct 1, 2015 04:09 PM
Pontsu
Oct 1, 2015 09:56 AM
