Misfire help! More Codes than i want to see ;-(
Old Nov 5, 2013 | 08:58 PM
luisg707's Avatar
Default Misfire help! More Codes than i want to see ;-(
Codes:
P0306 - Misfire Cylinder 6
P1314 - Misfire Rate Catalyst Damage Fault - Bank 2
P1316 - Misfire Rate Exceeds Emissions
P1111 - System Pass
I changed the spark plugs a couple months ago, should i also change the ignition coils? It idle's kind of rough in the morning when starting up, but after 10-20 seconds, its purring like a cat.
Old Nov 5, 2013 | 10:44 PM
luisg707's Avatar
Update on SIC Kitty..
I have a coolant leak, i checked underneath my drivers side and found where its leaking. could this be an issue with the water pump?
Attached Thumbnails Misfire help! More Codes than i want to see ;-(-88j7mnu.jpg
Old Nov 6, 2013 | 02:20 AM
Justicejamesb's Avatar
Take the battery out then you can see the water pump. If it's coming from there you'll be able to see it.
Keith Carter
16
Sep 29, 2015 12:26 PM
KarimPA
Sep 27, 2015 08:46 AM
tsimms7
Sep 15, 2015 12:43 PM
Bcrary3
Sep 11, 2015 10:36 AM
corysansburn
Sep 10, 2015 06:15 AM
