More crap to go wrong
Old Mar 2, 2012 | 04:09 PM
billbjork's Avatar
Default More crap to go wrong
Emissions control is going beyond the pollutants produced directly by combustion. In the near future, your gas tank will include a sensor to determine leaks. The EPA has known for years that leaking gas caps, or fuel systems in general, can and do produce a large amount of Volatile Organic Compounds (VOCs). Recent legislation has tightened VOC emissions and will require all cars to be equipped with a fuel system leak sensor. One such device has been developed by the Honeywell Corporation and is called a monolithic fuel tank pressure sensor. It is designed to mount either on the top or side of a fuel tank. The device will employ a single integrated circuit with a micro-machined silicon diaphragm containing piezo-resistors. Silicon was selected as a material because of it’s superior strength and quick response. The sensor will be able to detect a leak as small as .5 mm in diameter. Once a leak is detected, the automobiles information system will be activated to warn the operator of the leak.this looks like a new generation Evaperaror system
boiler
US Southwest
Dec 20, 2025 12:38 AM
Johnken
Apr 8, 2018 10:21 AM
Delta66
Oct 4, 2015 05:40 PM
robbing
Oct 1, 2015 11:24 AM
AnD3rew
Sep 26, 2015 06:06 PM
