more DSC issues
Old Mar 27, 2015 | 11:33 AM
Peperami's Avatar
Default more DSC issues
I'm slowly going made with my DSC light now . I have a problem with turning the light off. I have replaced the yaw sensor on the car but the DSC light won't go out. I took it to my local garage to turn the light out but they can't do it . Their diagnostic machine is saying the car is free from faults but they can't turn the light off. Does anyone have any suggestions as to why the light won't turn off ?
Old Mar 27, 2015 | 12:07 PM
rapala's Avatar
Could it be that there is a fault with the switch?
Old Mar 27, 2015 | 12:36 PM
Peperami's Avatar
Which switch and where could I find it ?
Old Mar 28, 2015 | 07:16 AM
rapala's Avatar
What engine do you have? Mine is the 2.2 diesel front wheel drive and I have a switch on the center console that can be used to disable the Dynamic Stability Control, I know that some cars have a small slotted coin tray there instead of the switch, probably the all wheel drive models though.
Old Mar 8, 2017 | 05:46 AM
racepit-jags's Avatar
Default Re DSC fault
HI I had the same issue
what I found it is ,its when the voltage drops from your battery
theses cars are very sensitive to voltage drop you will find that if your voltage is below 12.46 it senses a voltage drop and triggers the dsc fault also make sure the battery level is good
99xk8guy
May 28, 2024 09:36 PM
cissdm
May 3, 2016 06:02 AM
Nigels420G
Mark V - X 420G
Sep 17, 2015 10:29 AM
colinc1444
Sep 14, 2015 07:54 PM
