More headaches with my compressor swap
Old Dec 13, 2012 | 04:25 PM
disguay's Avatar
Default More headaches with my compressor swap
So I pulled my old compressor, installed the good one, pulled a vacuum, re-installed everything to get to the compressor and now the compressor clutch won't disengage. My thought is that the clutch that I installed was locked up from the start, but I'm just fishing for more ideas because I am so fed up with working on this problem. Everything that could have gone wrong has gone wrong and a simple 2 hours job has turned into a three day job and it's not even done. Anyways, here's my problem. My compressor clutch won't disengage. If I turn the a/c on or off it's still engaged. I thought it could be electrical so I pulled the compressor clutch fuse and the clutch still won't disengage. Do you have any good thoughts to get this clutch working other than just buying a whole new one?
Old Dec 13, 2012 | 07:27 PM
Bruce in North Dakota's Avatar
From: That Rectangular Hole in the Consciousness of America
Whack the clutch with a big rubber hammer while it's running, see if it disengages then.
(No - not kidding!)
Attached Thumbnails More headaches with my compressor swap-rubber-mallet.jpg
Old Dec 15, 2012 | 04:21 PM
disguay's Avatar
haha i'll try that. I was hoping that it was just frozen up but I didn't have enough ***** to smack it. Thanks!
Newark Nj Gang
Oct 2, 2015 02:39 PM
millertic
Sep 30, 2015 08:11 PM
dmatthewman
Sep 30, 2015 10:10 AM
dan102877
Sep 29, 2015 06:47 PM
