my x-type projects and installs
Old May 31, 2009 | 09:51 PM
  #81
dennis black's Avatar
Default adamesh grille
Old May 31, 2009 | 10:22 PM
  #82
ant1.0's Avatar
Dennis nice mods. Trying the same type of dvd setup(jensen vm9022 HU). Got nexxia harness adapter hooked up but no sound!! What wires didn't you use? Everything else works.
'02 X-type 3.0
Old Jun 1, 2009 | 09:55 PM
  #83
if the deck powers up it not the hot wire....did you connect the grey and white wires for the speakers? or did you use rca's
is this the adapter
is your wiring like this
Old Jun 1, 2009 | 10:26 PM
  #84
ant1.0's Avatar
Soldered the speaker wires, each match up. Yes the same adapter PC2-81-4. The deck has bluetooth, so i connected the blue/ blk tele mute also.
Old Jun 2, 2009 | 07:25 PM
  #85
try and disconect the blue/black wire and see what happens ..do you have a amp
Old Jun 3, 2009 | 09:08 PM
  #86
ant1.0's Avatar
Thank you for the help. Worked like a charm.
Old Jun 4, 2009 | 03:08 PM
  #87
no problem
Old Jun 11, 2009 | 06:53 PM
  #89
vinnie nice info that will save a lot of time ...i think i have seen that kit....
Old Jun 14, 2009 | 09:12 PM
  #90
Default wiper delay fix
if when you put your wipers in auto so it has a delay ...it just goes in one mode or stop half way on your windshield! heres the fix..so i can save you guys some money and diy
1..first you will need a a gear puller ...13mm socket
2..on your windshield wipers you will see a plastic cover flip it up with your finger ..so it can expose the 13mm nut you are going to take of
3..then after taking nut off, put your pulley on it and remove both wipers
4..now we have to remove the cowl ,there are about 6 plug fasteners use a screw driver and pop then out..now remove cowl
5..now you have removed that, while were at it change your pollen filter
6..now remove the 3 13mm nuts and pop the whole assembly out
7..now these are all the items you should have removed
8..now transfer the knew motor to the wiper assembly
9..button it all up your done
Old Jun 15, 2009 | 09:21 AM
  #91
ShaguarNYC's Avatar
LOL, Denis, you're the man! I have a friend just like you when it comes to car stereo diy work. Clean work that looks factory. Good stuff.
I like the new grill so much that I ordered one from adamesh. It came today too! Already painted. Cant wait to install it later.
I like the RX7 pic too. I used to drive a MKIII Supra Turbo. Here are pics of my Supra and my current X.
Attached Thumbnails  my x-type projects and installs-1_multipart_xf8ff_35_101-0189_img.jpg    my x-type projects and installs-4593_1158298753307_1102917201_457754_7889197_n.jpg
Old Jun 15, 2009 | 08:15 PM
  #92
im here to help ...youll love your knew grille your supra looks really nice i would of kept that
my rx7 turbo
Old Jun 16, 2009 | 10:24 PM
  #94
no problem ,go to ebay type in eclipse double din ...you want the avn series theres quite a few up there they all fit ...thats were i got mine from ....if you have any problems ill take mine out and give more details on the install ...you cant go wrong with the avn series,,i have a garmin nuvi navi and my avn5500 navi is better than my portable...when you set your destination on the avn5500 you just get up and go ..on the garmin nuvi you have to wait for the satalite that can take 5mins...i recommend the avn series they cant be beet for navigation dvd quality
Old Jun 24, 2009 | 02:32 PM
  #95
ShaguarNYC's Avatar
Not the best pic, but here's my new grill. I love the thing!
Attached Thumbnails  my x-type projects and installs-4920_1162260412346_1102917201_470761_5799469_n.jpg
Old Jun 24, 2009 | 02:37 PM
  #96
Disco stu55's Avatar
u said admesh paints it for u too, i was planning on ordering mine from mina
Old Jun 24, 2009 | 03:38 PM
  #97
ShaguarNYC's Avatar
yeah, you give them the paint code from inside the door. I didnt do a price comparison with mina because I liked the convenience of having it already painted.
Old Jun 24, 2009 | 06:51 PM
  #98
Default Transmision oil change
SHAGUARNYC YOUR GRILLE LOOKS GOOD
WRITE UP
1-difficulty = easy
2-parts = 5/16 allen wrench
3-fluids = 2quarts redline mt90 transmission oil
4-pump = you can get one from advance auto for $5
6- first jack up the left side of your x
7-look to the rear of your transmision and locate the 5/16 plug
8-let the fluid drain 1.5 quarts came out of mine..then lock it up
9-now move to the front of the car and loosen the 5/16 plug in the front
10-insert the pump with the redline transmission oli in it and pump
11-put tape on the threads on the plug and button here up your done
MY NEXT PROJECT WILL BE THE TRANSFER CASE
File Type: jpg
Old Jun 25, 2009 | 03:10 PM
  #99
ShaguarNYC's Avatar
This is a pic of my extensive upgrade project, LOL. I'm not mechanically inclined like Dennis, but thankfully the grill job is only remove and replace!
Old Jun 25, 2009 | 05:16 PM
  #100
H20boy's Avatar
good looking grille u 2. Great, easy mod that looks very nice.
