Name of part
Old Jul 28, 2014 | 04:07 PM
voltage39's Avatar
Default Name of part
Hoping someone can help me? I just called for a part and the guy wasn't sure what part I needed does anyone know the correct name for this part small hose in the engine compartment that had a split in it, you remove the cover and looked in the middle you see that hose, what is that hose called besides a pcv hose? Thank you
Old Jul 28, 2014 | 05:13 PM
Sharree,
I've moved your question from General Tech Help to X-Type forum. Members here with the same model will be best able to help.
A pic of the hose could make identification a lot easier ..........
Old Jul 28, 2014 | 05:38 PM
Slocs's Avatar
Does it look like the attached image (the old hose is the bottom one, the newer design replacement the top one)?
If so, the part number is C2S40863.
Here is an example on ebay: Jaguar x Type Emission Crankcase Control PCV Valve Hose C2S40863 | eBay
Regards
Rob
Old Jul 28, 2014 | 05:56 PM
wa3ra's Avatar
hmmm...5 dollars over retail!
Thanks for reminding me that I need to order one!
Old Jul 28, 2014 | 08:36 PM
1arrowdown's Avatar
If you have the one on the bottom make sure you replace it with the one on the top.
Old Sep 16, 2014 | 10:29 AM
voltage39's Avatar
Hi I have 4 new codes one is p0156, p0037, p0430 which is telling me that the 1st 2 codes is probably why we have this code. And last code p1111 which is nothing what i read..... So are the 1st 2 codes an oxygen sensor??? what do I order what is it called. Thanks so much
Old Sep 16, 2014 | 04:21 PM
Thermo's Avatar
Veteran: Navy
Voltage, see your other post. I have all the answers there. In short, you are after the "downstream O2 sensor" should that be your problem based on the codes that you listed.
Scott B
Oct 24, 2015 01:29 PM
wardo5757
Sep 11, 2015 11:31 AM
jaggermang
Sep 8, 2015 07:07 PM
DAN L
Sep 8, 2015 07:21 AM
1100me
Sep 7, 2015 06:26 AM
