Name of part?
Old Jul 11, 2020 | 11:25 AM
Wahooesprit's Avatar
Default Name of part?
Looking for the gasket for the piece next to the oil fill neck on the front valve cover that has an electrical connector--just wondering what the sensor is called and if I can still get the gasket
David
2005 X type
Old Jul 11, 2020 | 01:19 PM
avern1's Avatar
The unit is called Variable Camshaft Timing Solenoid. The seal is replaceable. My questions is. Is the seal leaking? If so unless it damaged? If not your PCV (crankcase vent valve) is probably bad and the excess crankcase pressure is venting thru the seal.
Old Jul 11, 2020 | 04:36 PM
Thank you---I put a new pcv valve and hose on in 2016, but will probably just get another one--Thanks again for your help
wrd0225
May 5, 2024 01:30 PM
62sunbeam
Dec 1, 2014 03:36 PM
04xtype04
Apr 26, 2014 11:09 PM
wrd0225
Nov 11, 2013 05:35 AM
The Coupe
Sep 19, 2011 01:20 PM
