valve cover gasket installation
Old Nov 10, 2013 | 08:10 PM
wrd0225's Avatar
Default valve cover gasket installation
I would like to know where can I get the WSS-M4G320-A3 sealant or what sealant is compatible. I can't seem to locate it. This is for the 2002 XJ8 valve covers.
Old Nov 10, 2013 | 08:18 PM
motorcarman's Avatar
A little dab of RTV is all you need at the cover/block seams.
I use Hylosil or VW oil pan white RTV sealant. It's kinda pricey but made for oil sealant.
You could use any RTV that you have around and it should work OK.
bob gauff
Old Nov 11, 2013 | 05:35 AM
Sean B's Avatar
Jaguar recommend 'Loctite Ultra Grey' if you can get it locally, although Bob's suggestions are probably as good. Just ensure all faces are minty clean on assembly.
dsnyder586
Dec 29, 2024 07:39 PM
bamforp
Aug 14, 2024 05:36 PM
hoodun
Sep 7, 2015 07:02 PM
philwarner
Sep 6, 2015 11:10 PM
Dallas XK8
Sep 3, 2015 12:17 PM
