Nav Screen Problem
Old Feb 11, 2008 | 07:13 PM
FactoryJaguarTech's Avatar
Default RE: Nav Screen Problem
I will look up that error code.
Old Feb 12, 2008 | 02:20 AM
badmojo's Avatar
Mine has been black a couple of times in the last year and a half when i started the car but it came back on after shutting the car off and restarting. works fine 99.999 % of the time.
Old Feb 12, 2008 | 06:47 PM
jag_genius's Avatar
if the Nav screen fails .. it's default is defrost for safety.. so looks like you need a new nav screen.. there is a place in California that rebuilds them. had 2 like that already.
Old Feb 12, 2008 | 06:57 PM
You know what they charge for that Genius?
Old Feb 12, 2008 | 07:09 PM
jag_genius's Avatar
i dunno .. never sent one yet .. customers wanted a new one.. they must have$$$
Old Feb 12, 2008 | 07:11 PM
at $3000 plus I would say so. Not for me thanks.
Old Feb 12, 2008 | 07:20 PM
jag_genius's Avatar
it's weird how some people don't flinch when you say $3000 and others cry when you say $500 ..
Old Feb 12, 2008 | 07:42 PM
jag_genius's Avatar
no pretty simple .. less then 10min.. just have to be carefull with the fiber optic cables .. the do no bend. and you wud have to verify part numbers before you install a used one.
Old Feb 13, 2008 | 02:59 PM
jag_genius's Avatar
ill ask
Old Feb 13, 2008 | 07:17 PM
ibjags's Avatar
Ive seen the screen go blank more then twice and both times it ended up being the navigation module in the trunk
only screens ive seen go bad were on xk8"s
for testing purposes its pretty much just plug and play with a known good module
better to pay diag at a dealer or just swap a nav module from another car to yours to verify fault
that is if you know of someone with nav in there Xtype thats willing to let you swap modules to verify your fault
before i spent money on any part with nav faults i"d definently verify module in trunk is or isnt ok first
IE nav module in trunk being module that you insert nav disc into
good luck
Old Feb 13, 2008 | 08:05 PM
jag_genius's Avatar
if it was a nav reader in the trunk .. then the climate control wud not default to full defrost.. Nav reader wud only affect nav and hard keys for climate wud still function. xk head unit is a totally different Nav system
Old Feb 13, 2008 | 08:36 PM
Gotta love it. Pick one. I like the denso system personally.
I have seen the reader pull down the screen once. I unplugged the nav module and screen came back. Not normal though, if screen dies, stays that way.
Old Feb 13, 2008 | 08:55 PM
ibjags's Avatar
jag_genius
You could be rite
Im just going by my memory on this one and as ive already stated im gettin old and the memory kinda go"s with the aging process too lol
