Need advice on gasket problem
Old 12-24-2017, 09:37 PM
Chris Hebb's Avatar
Default Need advice on gasket problem
My 2004 X-Type 3.0 is losing coolant extremely fast and could this mean a dreaded cracked block or head could this still mean that my gasket is blown this is a timely matter that I need to address as soon as possible as I am in the car dealing buisness and I want to sell this car it is in beautiful shape except this problem and with this problem I will take a loss on the car if I can only sell it the way it is im a DIY mechanic but something as major as this I would need to enlist help to change the engine as I don't have the right equipment but a gasket fix as long as my head isn't warped I could do if anyone has any insight on my problem such as how to differentiate between a cracked block or head and a blown gasket it would be extremely helpful
Old 12-24-2017, 09:47 PM
Unhingd's Avatar
Received 4,640 Likes on 3,362 Posts
Originally Posted by Chris Hebb
My 2004 xtype 3.0 is losing coolant
Sorry...you're on the wrong forum.
Old 12-25-2017, 08:29 AM
SinF's Avatar
Received 2,140 Likes on 1,461 Posts
Wrong forum, but ...
Cracked block won't hold any compression or leak down on one cylinder. Leaking gasket generally will hold some compression and leak-down and on impacted cylinder, and depending on type of leak will increase pressure in the cooling system that you can detect.
Old 12-25-2017, 09:19 AM
Dogbreath!'s Avatar
Using punctuation would make the post a lot easier to read.
Old 12-26-2017, 06:50 PM
Queen and Country's Avatar
Received 2,380 Likes on 1,607 Posts
Default In the car dealin biz
Old 12-26-2017, 09:36 PM
Unhingd's Avatar
Originally Posted by Queen and Country
vwbusbits
03-08-2016 02:49 PM
Lagonia
03-03-2016 09:18 AM
jagosaurus
11-05-2013 11:42 PM
OldMike
General Tech Help
09-05-2012 09:57 PM
XJ40 ( XJ81 )
01-22-2006 09:18 PM
Quick Reply: Need advice on gasket problem
