Noise from back of the car when turning steering wheel
Hello,
You guys have been so helpful to me with my previous issues - I truly appreciate it!
However, recently when driving on the motorway, when my steering wheel is turned left, I hear a strange noise coming from the back end of the car. If my hearing is on point, the noise would be coming from the back-right.
What could it possibly be? Power Steering fluid?
Noise doesn't occur when turning steering wheel to the right.
I don't know where to start from or what to replace.
If you are positive the noise is coming from the rear then it can't be power steering fluid. That is all up front. There are a few inspections you can do to narrow it down.
1. Take a look at the rear of the vehicle from about 8 to 10 feet away at the rear.
Does the top of the tire appear to look like it leans in towards the top of the tire?
2. Inspect the tread wear for the right rear tire. Does it look like it is wearing different on the inside compared to the outside?
3. Lift the right rear tire off the ground. Grasp it at the top and bottom and rock it back and forth. Then do the same things from the left/right sides. Does it have significant movement?
A tilting wheel and abnormal wear would be a failed upper control arm. The significant movement would indicate a bad wheel bearing.
Try out those inspections and get back with us for more information.
Like Avern mentioned, check the control arm and wheel bearing. That is a good place to start. If you replaced tires that had a non-normal wear pattern the issue that caused that wear pattern is still there. Address the underlying problem soon or your tires will soon wear out the same way.
The sound is in the back of the car, in only one direction?
Before you go crazy, check the anti-roll bar bushings and end links on the rear.
Also, if your rear tires are leaning in at the top, check the rear front upper and lower control arms. There is a whole thread here on adjustable replacements for the upper arm, most of the suppliers here on the site have the lowers in stock.
