Need a definitive answer to the phone problem
Old Jan 23, 2008 | 05:39 PM
BuckMR2's Avatar
Default RE: Need a definitive answer to the phone problem
Ask Jag.If you email Jag customer services with the last 6 of your VIN.
They will email you back with what was fitted to yoiur car when it was built.
Old Jan 23, 2008 | 06:49 PM
FactoryJaguarTech's Avatar
04 X-Types didnt come standard with bluetooth. It was an accessory fit up to 2006 model when it became standard in the XJ and 2007 for the XK. If you do not have bluetooth prewire, then it will be tough to put it in. PM last 6 of VIN to me and I will look for yo.
Old Jan 23, 2008 | 10:39 PM
tarheel72's Avatar
so if I do a link up search with my phone and it does not find a blue tooth device then can I assume that it is not active? Or is there something you have to do to activate it in the car? The buttons are on my audio system, but they don't seem to activate anything.
Old Jan 24, 2008 | 06:03 AM
Every jag has the buttons. On the audio unit you press the phone button,
it should say no phone. Pm you last six vin again and I will let you know if
it is prewired. If it is I may have a bluetooth module laying around.
Old Jan 24, 2008 | 12:12 PM
Size:  6.3 KBName:  X6JYMSAAB5.jpg
Size:  6.1 KBName:  AudiX6JYM-2.jpg
Nice one FJT
Jim
Old Feb 1, 2008 | 07:28 PM
Sorry TG just read this post.
Checked your VIN. Voice activation pre wire, but no Blueteeth in your vehicle.
Nicely optioned car otherwise. Also to be perfectly honest, I would go aftermarket for your bluetooth. Heard Parrot is a good way to go.
Edit here: Also your warranty expires end of this month, so if you have anything at all needing fixed get it in there immediately.
Old Apr 2, 2008 | 08:23 PM
Something needs programmed. Pecus B may be Phone module? Not sure though. If you installed the phone module etc, you definitly need it programmed to the car. Dealer only. That should get rid of your Pecus error.
Old Apr 3, 2008 | 04:45 PM
pu5hkar's Avatar
hmmm
Old Jan 25, 2009 | 05:01 PM
Real_Tech's Avatar
Pecus B, bluetooth moduel not configured. Take it too the dealer and have them configure blutooth module with the IDS, it's youronly choice.
Old Apr 19, 2010 | 05:58 PM
canman's Avatar
Default Is a 2002 X-Type w/Nav w/Pre-wired Voice w/Factory phone Bluetooth Capable?
Did the 2002 X-Type with the "Pecus B" error in this thread successfully install the OEM Bluetooth?
Talking to Nalley Jaguar, we're thinking that such a 2002 (like mine) is compatible, but I would like to know for sure before taking on this project. Has someone installed Bluetooth successfully as this thread suggests? If I'm wrong, I can't return the parts, and will loose on the shop time to program the module.
I think a lot of 2002, 2003 owners would be interested to know.
Old Apr 20, 2010 | 10:37 AM
jjpopo's Avatar
I have a 2004 x-type and did successfully install bluetooth. I purchased all of the parts from Nalley Jaguar and was very satisfied with the customer service from Dan Wicker. My car has the satnav and also the prewiring for phone and cd changer. After installing the new optical harness (needed to add another module), phone module, bluetooth module, and microphone, I did have the "Pecus B" error. The phone was functional but I needed to go to the local Jaguar dealer and have the programming done. I am very happy with the addition of the bluetooth and also the fact that it is as the factory would have done it.
Old Apr 20, 2010 | 12:26 PM
canman's Avatar
Thanks, I'm sure it works for 2004, but Jaguar says it won't work for 2002, however the person above seems to have gotten it to work.... Dan and I both feel that it will work given your 02 is equipped as above, and if so I think a few of us 2002 / 2003 owners would like to know and so add this to our cars. So has anyone been successful at installing it in an 02?
PMKimpton
Aug 3, 2019 08:22 PM
jdzubas
Oct 4, 2015 09:14 AM
OkieTim
Sep 8, 2015 04:48 PM
carcycle
Sep 7, 2015 10:22 AM
OkieTim
Sep 2, 2015 12:48 PM
