Need to fix lower mesh grill
Old 06-18-2008, 01:08 AM
Mazarin's Avatar
Default Need to fix lower mesh grill
How is it attached? The top passenger side is out a bit and I want to get it back in, but I don't see anything it would attach to.
See how there's a light spot on the grill under the high beam? How do I fix this!?
Old 06-18-2008, 07:04 AM
jvegas's Avatar
Default RE: Need to fix lower mesh grill
there should be a clip that holds it on. look at the drivers side to see how it is held on. Your clip may have fell off if you don't see it.
Old 06-18-2008, 02:25 PM
spielnicht's Avatar
Beautiful car, I just finished turning mine into that Jaguar original parts are mighty expensive, but worth it.
As the others said, there is a hook at the top that can be taken off with hex key, it could have come loose and fell. Look on the opposite side and compare. If that's the case, you'll need to be creative and find a way to fix it because a new grill from the dealer is now $370. Yes, that much for a small piece of metal, ridiculous.
aholbro1
08-05-2021 05:02 AM
GordoCatCar
01-02-2017 01:10 PM
Quantico
10-13-2015 10:34 PM
bigdhenderson
09-29-2015 05:29 AM
1964Daimler
09-09-2015 11:28 AM
Quick Reply: Need to fix lower mesh grill
