need help my 04 x type is stuck in park
Old Sep 12, 2013 | 04:06 PM
oceguera's Avatar
Default need help my 04 x type is stuck in park
my car is stuck on park i was driving and run into a hole my rim is bend and my car shut off and i put it on park now is stuck in park and wont start. i was able to put it in nautral to push out of the road
Old Sep 13, 2013 | 02:11 PM
Stuart Beattie's Avatar
Hi oceguera,
you need good mechanical advice so I would be careful doing anything to the vehicle as it does not sound driveable. As long as the car is secure (locked), I would leave it where it is until you have good sound advice. Trying anything without knowing the issues will damage your car even more. You are having a bad day so try not to make it worse.
Please follow this up and I hope you are okay?
Regards and good luck, Stu
Old Sep 13, 2013 | 07:36 PM
oceguera's Avatar
yes thats what im goin to do i just got the car not to long ago :/
Old Sep 13, 2013 | 08:18 PM
motorcarman's Avatar
You need to pry the selector lever surround bezel trim and reach down on the left side if the lever housing.
You will see a black plastic lever arm. You need to move the small plastic lever and pull the gear selector lever to reverse, neutral etc. Use a long screwdriver or something.
I forget what direction to move the small plastic lever to release the selector lever.
See page 2 of the TSB. The part called mechanism shaft is what you need to move.
bob gauff
Old Sep 14, 2013 | 12:53 AM
oceguera's Avatar
i did that allready but the car wont star and if i put it on park again it get stuck
Old Sep 14, 2013 | 01:19 PM
astromorg's Avatar
I haven't checked the wiring diagram, but is it possible that when you hit the pothole and bent your wheel, the inertia switch tripped cutting out the fuel pump among other things?
On RHD cars the switch is by the driver's right knee, accessible through a small hole in the footwell trim panel. Reach through and press the rubber button down, just in case it has tripped. LHD cars will be similar, one side or the other!
Old Sep 16, 2013 | 10:58 PM
oceguera's Avatar
im goin to try that thanxs
Sprayall
May 30, 2021 08:13 AM
tberg
Sep 7, 2015 07:32 AM
Sprayall
Sep 3, 2015 07:49 PM
dcvickers
Sep 2, 2015 06:14 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
