New braking system
Old Oct 1, 2016 | 11:41 AM
scottpix's Avatar
Default New braking system
Hi folks scottpix here, just new to the forum.
I`ve just got my first jaguar, but unsure about the braking system.
My question is - is there some sort of sensor that slows you down to a gradual stop, sometimes my brake pedal feels hard and I cant stop exactly where I press the brake and it keeps rolling slowly to a stop, is this a problem with the brakes ? I read online that it could be a vacuum problem, id be interested in your thoughts.
Model X-Type 2005 d sport
Scott
Old Oct 1, 2016 | 11:52 AM
NBCat's Avatar
Based on your description, it may be a non-functioning booster or other issues with one or more calipers. Did it pass MOT?
Old Oct 1, 2016 | 12:21 PM
scottpix's Avatar
Thanks NB yeh it sailed through the mot.
Old Oct 1, 2016 | 01:18 PM
I've just got my first Jaguar, but unsure about the braking system......
Welcome to the forum Scott,
I've moved your question from General Tech Help to X-Type forum. Members here with the same model will be able to help.
Old Oct 1, 2016 | 01:46 PM
avern1's Avatar
The brake booster may be a problem but I would first check the vacuum check valve for the brake booster. There is a line running from the top of the intake manifold to the brake booster canister. In between is a foot-balled shaped housing. That is the check valve. Check if for cracks or swelling.
Old Oct 1, 2016 | 10:03 PM
Thang Nguyen's Avatar
When you step on the brake and feel hard and the car slowly roll to the stop; It not suppose to be like that in any type of car; 1st- may be the brake lines are clogged up, not likely on all four, 2nd- may be the caliper pistons got stuck, again not likely on all four but possible, 3rd- may be master cylinder got stuck, 4th- vacuum booster or vacuum hose leak, check all this out.
Old Oct 5, 2016 | 02:18 PM
scottpix's Avatar
Thanks for your advice folks, got a brake check at the local garage on Friday.
MrsToadsWildRide
Sep 7, 2016 07:16 PM
rhscare
Sep 6, 2016 05:46 AM
MaximA
Sep 6, 2016 04:14 AM
reedjs
Sep 4, 2016 10:13 AM
Catsgame
Sep 1, 2016 07:36 PM
