New Double Capacity 02 XTPE Radiator
Old May 4, 2025 | 09:20 PM
rm1111's Avatar
Smile New Double Capacity 02 XTPE Radiator
Hello All,
I still have my 02 jaguar xtype 3.0 with 156K miles on it.
I figured when in indiana summers the temperature gets hot 85-110 F degrees why not.
I bought a brand new racing radiator for my jaguar xtype. It basically holds double the coolant capacity vs the standard.
I will have my mechanic install it since the fans, thermostat, fan relay, and all coolant hoses have all been replaced.
I have a feeling the car would benefit greatly in the unforgiving heat.
I see guys with nissian 300z' with a 1000 horse power and 3 racing radiators installed so i figured why not ?
Any thoughts on my idea?
Old Jun 22, 2025 | 04:13 AM
rm1111's Avatar
Smile NEW JAG- X Type Racing Radiator worked!!!
UPDATE and the new racing radiator work EXCELLENT !!!
It solved my engine overheat heat problem with using the original fan module sensor.
I cant tell how HAPPY i am finally !!! I highly recommended for your jag x-type !!!
I bought it for 180.00 US paid 180.00 to swap it out. You will love it !
Old Jun 22, 2025 | 04:30 AM
rm1111's Avatar
Smile UPDATE on DSC DASH Error
UPDATE, I took the advice 2 of you suggested, and replaced both front wheel bearings on my 02 Jag- X type. I already replaced the clock spring, ball joints, springs, and the entire suspension and subframe. When you turn on the car, the now there are no errors, but as soon as you move the DSC Error comes on.
FYI - Only the right reluctor ring, which was cracked, was replaced. The DSC Error did not go away.
I will replace the left reluctor ring in the near future.
Now the car no longer jerks roughly when making right turns, but the error still returns once you move and drive straight.
I drove up to 90 MPH to see if I can feel anything. I feel a slight jitter, but nothing like how bad it used to be.
Someone recommended checking the blue connection thing, but I can't remember which one it is.
Any thoughts on finally resolving this issue?
Old Jun 26, 2025 | 11:34 PM
Mr rx-7 tt's Avatar
Originally Posted by rm1111
Hello All,
Where did you purchase this? Link?
Thanks.
Old Jul 5, 2025 | 02:31 PM
rm1111's Avatar
Default Jaguar x type racing radiotor
I purchased the racing radiator online just google it.
Rm1111
Old Jul 6, 2025 | 10:18 PM
95naSTA's Avatar
I wouldn't have imagined they were easy to find but there are multiple options on ebay.
arctic_man
Jun 24, 2025 05:05 AM
Lcgi
Oct 5, 2014 07:01 AM
konshu
Aug 21, 2012 01:15 AM
Xx_Four_Stroke_xX
Jan 19, 2011 07:51 AM
Walter1982
Apr 23, 2009 06:34 AM
