New member hello all
Old Apr 17, 2019 | 10:42 PM
matthewhenley's Avatar
Default New member hello all
So I have a 2009 Jaguar xtype 2.2d sport premium with auto gear box. Been told I need new front lh and rh drive shafts, been looking on ebay but having trouble finding the correct ones for my car, any body point me in the right direction please.
Old Apr 17, 2019 | 11:22 PM
Dell Gailey's Avatar
https://www.britishparts.co.uk/jagua...ine-axles-c406
Also look at SNG Barratt
BlownKitty's Avatar
Interesting..
A 2009 X-Type that needs both front drive-axles/constant-veloicty shafts replaced?
Greetings from "across the pond" Matt,
Why do they need to be replaced? What did the shop/dealer/____ give you as a reason why they need to be replaced?
Cheers,
BK
Old Apr 18, 2019 | 08:13 AM
Default Drive shafts
Originally Posted by BlownKitty
Interesting..
Cheers,
BK
Hi BK,
I had a constant noise when driving and I assumed it was the bearings in the hub/s, so my guy had a look, (who I trust) and said the hubs, were OK but there is movement in the drive shafts, more so on one side than the other, but advised me to get both done.
Old Apr 18, 2019 | 03:06 PM
Just make sure you read in this forum how to do the right side one. It's not like the left or an ordinary car by other manufacturers. If you don't do it correctly, you mess up the seal in the transfer case. Then you really are in a mess.
Old Apr 22, 2019 | 11:11 AM
JaguArvid's Avatar
is the noise a kind of whining noise from below the cabin while the engine is cold? it can be propshaft center support bearing then which needs a greasing, see below thread.
https://www.jaguarforums.com/forum/x...ring-faq-9853/
EDIT: just realized it's a 2.2d, this means it's fwd only, right? so this wouldn't be a problem? my bad if so..
Old Apr 25, 2019 | 07:41 AM
RudyF6's Avatar
SNG Barratt sometimes offers aftermarket parts when available. I would feel better about ordering from there, as they will verify the application against OE info. They've saved me some money a couple of times!
Burdedw
Jun 21, 2013 04:19 AM
jaguarjohn2468
Sep 24, 2010 06:17 PM
AltsXJ8
Apr 5, 2010 08:43 AM
shanemcconn
Mar 2, 2009 11:10 AM
