New member with quick question
Old Dec 19, 2008 | 03:12 PM
H20boy's Avatar
Default RE: New member with quick question
I'm not familiar with the x-type specs on the wheels, offset, etc. But my first guess is that the offset is way off to be hitting the fenders. Wider wheels and tires add to the problem even moreso. Other x-type owners will drop by and chime in on this also, but your best bet is to take the factory specs and get yourself new rims and tires, maybe go +1 on the diameter, but keep the rest as close to spec as possible. I don't like chrome either anymore. Maybe you can talk her into a brushed aluminum with a chrome lip...much more tasteful in my opinion.
I like these two in the 18" option for the x... but I always tend to lean towards the 5-6 spoke type in my cars.
Old Dec 19, 2008 | 05:14 PM
christo's Avatar
Dont know much about your rim problem, but I ran those Nankangs for a while on my veedub with hp racing evo rims. I really don't have anything negative to say about them, but they came with the rims. Someone once said they were like goodyear in Japan and I cracked up. Maybe I can say they treadware is a little weak.
Old Dec 20, 2008 | 02:29 PM
djdex's Avatar
I believe the offset should be 42mm or more. I read somewhere that the max tire width for the x-type is 225, so you could reduce size to that, sadly I can't be certain that'll be enough, can you visibly check if 5mm on the outside of the rim will be enough? If not will a friendly retailer try one on for you?
Personally I only ever fit manufacturer rims having had these problems in the past.
Edit - You can have the front wheel arches rolled back professionally, that & 225 tires would likely cure it. Just for info - the rear arches cannot be rolled on the X-type.
Old Dec 22, 2008 | 09:22 PM
Size:  6.3 KBName:  AudiX6JYM-2.jpg
Size:  6.4 KBName:  T15ESSST101-1.jpg
Size:  9.9 KBName:  tshirt03-2.jpg
Hey Jagmcnag........check out the "x type FAQ quick link" post within the x type section.
There is post after post after post ....all about rim sizes / tyre sizes / offsets etc etc
You may find it useful
All the best
Jim
PMKimpton
Aug 3, 2019 08:22 PM
Chet Ramnarain (bozzner)
Sep 3, 2015 07:47 PM
arnoldmilk
Sep 3, 2015 07:42 PM
KarimPA
Sep 3, 2015 07:32 PM
