new spark plugs killing coils?
Old Jul 3, 2018 | 04:07 PM
iownme's Avatar
Default new spark plugs killing coils?
i replaced the spark plugs about 3 months ago at 110,000 miles.
since then i have had 3 coils fail... even a new (aftermarket) coil has just failed.
is it possible that these new spark plugs are the cause or is it just coincidence?
new plugs are champion platinum power 3401.
old plugs were AGSF22FSM5G no visible brand name
Old Jul 3, 2018 | 04:11 PM
Dell Gailey's Avatar
https://www.jaguarforums.com/forum/x...x-type-157113/
Old Jul 3, 2018 | 05:56 PM
iownme's Avatar
thanks for the link Dell but unless im missing something that didnt answer the question.
in fact is suggests that the plug i have is satisfactory...i.e platinum and a known brand.
i do gap my plugs to around .52 .55
my original bad coil came up with the original plugs
Old Jul 4, 2018 | 01:51 AM
It is the answer. Plugs are correct, not causing the coil problem. Better check proper gap. Nearly every search I have done, each mfg. Says "do not gap/regap" as they are set correctly from the factory. Note each of the attached brands, all for 2006 Jaguar X Type (mine) are different.
Old Jul 4, 2018 | 02:04 AM
Of course, that still would not affect nor cause a coil problem.
Old Jul 4, 2018 | 06:22 AM
iownme's Avatar
thanks for the reassurance.
i didnt think it would/could affect the coil but i figured id ask the collective.
ive always gapped my plugs as
a. there is no "one gap fits all"
b. after checking gap on new plugs found they were way off the necessary specs.
my current champions were set at about 0.45 from the store
unpredictable1
36
Jun 20, 2017 09:05 PM
GaryinOregon
Jul 11, 2010 08:18 PM
Kennedy
Oct 14, 2009 07:10 AM
2000SType40
Sep 21, 2009 05:46 AM
seifen
Apr 12, 2009 02:30 PM
